I will occasionally reauthor one of my DVDs with a custom made menu, so that I don't have to wait through previews or wade through complex menus to get to the features I want.
In order to do this, I'll usually reencode the DVD material I want in order to fit on a DVD-5 (with DVD-Rebuilder), and then add a menu to the reauthored DVD using TMPGEnc DVD Author. I find the "Add DVD Video" function of TDA to be very useful, since it can keep the chapters that split the original tracks without my doing any work.
However, I've recently been feeling trapped by TMPGnce DVD Author's limited menu capabilities and have been looking for a more fully featured reauthoring program. However, I can't seem to figure out any way to import pre-authored DVD Tracks into any other program, as I can with TDA. Other programs can handle VOB files, but that still leaves me with a whole bunch of work.
Am I missing something? If there is a way, can anybody tell me how to import a track from an already authored DVD (along with the original chapters) into any other authoring program, such as DVDAuthor, DVD-Lab, Maestro, or even Scenartist?
Thanks in advance =]
DVDLab will let you import chapters in the following formats: *.txt;*.chp;*.eds_chpt
Cheers, Jim
My DVDLab Guides -
Thanks for the reply, I had noticed that, but I don't know any easy way to extract chapter information from a DVD.DVDLab will let you import chapters in the following formats: *.txt;*.chp;*.eds_chpt
I guess the logical next question is: does anybody know an easy way to extract the chapter information from an authored DVD in some way that would satisfy the format requirements for DVDLab?
Also, on the same note, is there any easy way to end up with a piece of video that consists of one track of a bunch of VOB files in DVDLab (other than joining all of the VOBs and cutting each track out yourself)?
-- TheUglyDuckling -
You might to give DvdRemake Pro a trial to see if that meets your needs.
regards, jrisch
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 23:41 -
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 14:54 -
TMPGenc DVD "add a note page" ?
By Spassvogel in forum Authoring (DVD)Replies: 0Last Post: 6th Aug 2009, 00:07 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45
