In the Encore manual in the "Building the finished project" pg 149 there is the warning "Do not make a DVD folder and then burn that to a DVD".
Does anybody know why they make that warning? I tried it once onto a DVD-RW and it worked ok.
I made the folder and tested using PowerDVD to be sure all the menus were working as desired, then burned from there using Prassi.![]()
because then they have no control on the settings to burn it .. (i suspect)
prassi burns a UDF/ISO bridge for dvd by default and nero burns a ISO only by default for dvd ..
as an example ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Not sure what you mean by "bride" or what it would be if a typo.
To get more specific with my original question.
Since I got away with it once, do you think there is a major risk?
Using Prassi, is that UDF/ISO DVD format liable to be less compatible? -
I had problems when creating a folder and burning with nero. Using Encore to burn the project without changes and the resulting disk was fine. So I don't know why but what the manual says is true.
i meant 'bridge' .. sorry ...Originally Posted by halek
as for using prassi -- keep using it, i burned several 1000's of disks with it and never a problem ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M is dead right. I know someone who got into all sorts of trouble creating images with Sony DVD Architect and burning with Nero.....big compatability issues. I suspect Encore will output an image with a particular structure in mind for burning - I'd expect UDF 1.02. Say you took an image from Encore into some other burning sofware and didn't get yr settings right then it's a whole world of trouble.
So it sounds like the UDF format is the key.
I wonder if we could do the community some good by collecting info about which burning software must be avoided if you want to burn from a DVD folder?
Or maybe it is how to setup your software if you want to do that? I probably just got lucky using Prassi because I did not make any special settings.
Thanks to all!
Need Help With An Avast Warning
By hech54 in forum ComputerReplies: 9Last Post: 21st Feb 2010, 03:18 -
Burning DVD Encore 2.0
By Usagi Tsukino in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2009, 14:10 -
Encore DVD 2.0 burning question
By Flying Doctor in forum Authoring (DVD)Replies: 11Last Post: 22nd Aug 2008, 05:49 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43 -
Warning: implode()
By handyguy in forum FeedbackReplies: 1Last Post: 24th Aug 2007, 13:02
