For some reason when I try to capture video using VDub I can no longer select Divx.
I've re-installed it twice and it still doesn't show up for some reason.
Is this a problem in the latest VDub or something I'm doing?
I experienced a similar problem when I had PICvideo MJPEG codec installed on my machine and the installed a PVR program with it's own MJPEG codec, If I looked up my codecs in the control panel, they were both there, but only the most recently installed one would show up in VDub, Is it possible that you have any other Divx type codecs on your machine that register themselves as the primary codec? Some types of codecs don't play nicely with others. I will admit I don't have the Divx codec on my system but perhaps it's the same type of problem.
How to convert DV to DivX or XviD using Virtualdub
By Baldrick in forum User guidesReplies: 52Last Post: 1st Dec 2011, 18:04 -
DivX 7 in VirtualDub
By hgd4th in forum Newbie / General discussionsReplies: 5Last Post: 24th Feb 2009, 04:40 -
What exactly is the problem Virtualdub has with Divx multipass?
By Onceler2 in forum Video ConversionReplies: 14Last Post: 20th Aug 2008, 19:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 12:45
