looking fo the best site to read up on converting vhs to dvd...looking to buy the unit that does it all ,.if any one can give a idea if this is a good investment..and trying to find the quality is worth it....
You need to give a little more information.
Do you want to add titles/credits ?
Do you want to edit the footage at all ?
Do you want to manipulate the audio at all ?
If the answer is (and will always be) no to these questions, then buy a DVD Recorder and perhaps a Timebase Corrector (if you are really serious) and be done with it. Have a read of the first 4 posts in this forum https://www.videohelp.com/forum/viewforum.php?f=43 as well.
If the answer is yes to any of those questions then Capture and Conversion forums here are a good play to start. However if you really want good answers, you need to ask specific questions, not vague like this one.Read my blog here.
If all you want is simple conversion, buy a Pioneer or JVC DVD recorder. Both have excellent quality at the higher settings.
If you're thinking about one of those combo units, they aren't regarded highly. First, there are compromises in quality and features (compared to seperate units). Second, if there is a technical problem with the unit, you'll have to send the whole thing to the shop.
As suggested, you might want to consider a Time Base Corrector for better video stability. You'll have to have seperate units to connect a TBC.
If you want custom menus on your DVDs, you can copy your home made DVDs to your computer hard drive, then re-author them. You can even do some simple editing.
Good Luck!
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 02:56 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
