    Jan 2005
    Louisiana
    Yes i'm sort of new to this,But i have a Sony HX-900(160gb hardrive).I've recorded about 10 disc(-Rs) so far. Recently i bought a spindle of Memorex DVD-Rs And had about 5 come up with a code saying disc is dirty when it wasn't, when recording from the harddrive...I had good luck with the few Sony DVD-Rs i've used,But I want to Do most of my recording on DVD-R,& i understand that there are Great disc disc out there.Which should i go with?? What to look for?? I heard there was a Good brand that starts with the letter I .. Help would be greatly appreciated. I need to buy some more disc but i want a GOOD quality & to a point money is not the issue. I Just want A DVD-r that will work good with my Sony Hx-900.
  2. Ive been using prodics's at 40 cents a piece, but ill probably get flamed for saying it
    For absolute quality most prefer Tiayo Yudens, at least 80 cents a disc. most discs that were made in japan seems to get good results. Discs made in Tiwaan are lower quality
  3. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    Many of the member here will agree that Taiyo-Yuden is simply the best you can buy. They can be found at Rima.com, Meritline.com, & Supermediastore.com. Just use the links at the bottom of the page.
    https://www.videohelp.com/
    If you prefer to buy your discs at a local store, look for the following brands: Maxell, Fuji, & maybe Sony. Then check the label for the words "Made in Japan."
    Jan 2005
    Louisiana
    Thanks alot ,Thats what i wanted,INFO !!!! Anymore, please post
  5. Member Skith's Avatar
    Bottom of the ocean
    Note: Maxell "Made in Japan" could also be Maxell's own in-house manufactured discs. Maxell made media is also regarded as top quality (perhaps even rivaling Taiyo Yuden).
    Success is a combination of recorder, media, and player. You might consider buying a sample pack from an online store (the three listed above should sell such a pack). This would allow you to test for a suitable media without buying a whole spindle of discs that might end up wasted.
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
