  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Do I want to have my computer to sleep after a certian # of hours, or would I want to have harddisks shut off ever? Or should just let computer to run 24/7?
    What does shutting down harddisks do? Pros/Cons?
    What We Do In Life, Echoes In Eternity....
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Shutting down the hard drives is OK if you're trying to reduce heat, noise, and power consumption. It may be hard on the device itself if it has to spin up a lot more often than if you just leave them running all day.
    I would do it if I shared a bedroom with a computer just to cut out some noise, but at that point I think I'd just be shutting the whole system down.
    FB-DIMM are the real cause of global warming
  3. Banned
    Nov 2002
    Pgh Area
    Sometimes they are a bitch to awaken. One machine, all I gotta do is nudge the mouse, awake.
    Another machine, I play with the mouse, actually, touch screen a dozen times before it wakes up. Click keys, etc.
    Then I go into settings and select "Never" for HDD and Monitor.
    Rather they don't lock up, or seem to be locked up.
    Cheers,
    George
