Results 1 to 30 of 32
  1. Anonymous
    Guest
    Is it possible to fill(paintcan)with transparency?
  2. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    I just use the smallest eraser. I'm sure it's possible, but I can't remember the settings. I think it has to do with setting white as transparent.
  3. You can set any color as transparent.
    I usually use black or white, they're easiest to see against your work.
    Hit SHIFT+CTRL+V to open the transparency dialog.
    Cheers, Jim
    My DVDLab Guides
  4. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    I have to press buttons? WTF? I'm just going to click with the mouse.
  5. Anonymous
    Guest
    Ask and you shall receive!
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    along the same lines -- anyone can tell me how to make a animated jpg file like this one ? what software does it ?
  7. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    I thought they had to be GIF to be animated. Animation Shop comes with PSP.
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    yea i thought so -- i think it is really a mislabled gif ..
    though you can do it with this (java trick) http://www.catenary.com/howto/grow.html
  9. PSP Animation shop will do a gif like that.
    Download it, and open it in Animation shop, you'll see how it's done.
    Cheers, Jim
    My DVDLab Guides
  10. Член BJ_M's Avatar
    Jul 2002
    Canada
    i know how to make animated gifs -- hahaha , made 100's of them ..
    i was asking about animated jpegs ... the file above is labled a jpeg and windows says its a jpeg - but im sure it really a goofed up gif ..
  11. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    If I right click and click on properties it says it's a GIF. Maybe you can use whatever extension you want so long as the data is recognized.
    Nothing can stop me now, 'cause I don't care anymore.
  12. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Especially if the associated application is the same for both. The app knows the difference as soon as it parses the header.
  13. I thought you guys were talking about Sony's new handheld for the first three or four posts.
    If it's wet, drink it
    My DVD Collection
  14. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    You're too heavy into gaming Russ.
  15. Anonymous
    Guest
    Right click to save it.You can only save it as a gif
  16. Член BJ_M's Avatar
    Jul 2002
    Canada
    funny - i can only save it as a jpeg ....
    and it shows up as jpeg in properties .. it must be the reg patch i did to block reading of avi files properties i suspect
  17. Anonymous
    Guest
    Actually,it only offers gif and bitmap as options.if i save it ,it still gets saved as a jpg anyway.????????
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    i told you its a goofy file
  19. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You should change the title of the thread!
    I keep thinking you're talking about the upcoming PlayStation Portable
    Kevin
  20. Член BJ_M's Avatar
    Jul 2002
    Canada
    not my thread - i only hijacked it ...
  21. Member Conquest10's Avatar
    Chicago, IL
    Funny, I instantly thought Paint Shop Pro.
    His name was MackemX
  22. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    the frames open up in my gif animator.
  23. Originally Posted by Conquest10
    Me too. What else could it be?
    Cheers, Jim
    My DVDLab Guides
  24. Член BJ_M's Avatar
    Jul 2002
    Canada
    i first read it as PCP myself and started feeling buzzing top of the roof of my mouth ....
  25. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Angel dust?
  26. Член BJ_M's Avatar
    Jul 2002
    Canada
    where ?
  27. Anonymous
    Guest
    you didnt smoke it right
  28. Член BJ_M's Avatar
    Jul 2002
    Canada
    what is the correct way then ?
  29. Anonymous
    Guest
    How is PCP used?
    PCP is snorted, smoked, or eaten. For smoking, PCP is often applied to a leafy material such as mint, parsley, oregano, or marijuana. The onset of effects after smoking is rapid.
  30. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    mixing drugs is like drinking mixed drinks.
    Suck it up, be a man, smoke it straight or not at all
