Results 1 to 12 of 12
  1. I have 2 DVD drives on my Gateway 930 MHz Intell Pentium III computer.
    Drive One is a Pionner DVD-ROM DVD-115
    Drive Two is a HP Writer DVD 300i
    I am using what are suppossedly "professional grade" DVD+Rs.
    Memorex 4X DVD+R White InkJet Printable 4.7GB
    Now all my purchased DVDs play just fine in either drive with NO ERRORS of any kind.
    But my "home movies" or backups created with DVD-Shrink DO NOT play well in either drive, not even in the HP drive that created them. They play part way and begin to freeze up about half way through until they finally just stop.
    Now I know NOTHING is wrong with the DVDs. They play just fine on any of my stand alone DVD players WITHOUT ERRORS.
    But for whatever reason my 2 DVD drives will not play them all the way through.
    So what is a good DVD player (doesn't even have to be a writer) that will play a DVD+R all the way through with no errors?
  2. Almost all DVD-ROMs will play DVD+R. I have the Pioneer-116 DVD-ROM and HP DVD-Writer 200i. Both play DVD+R without any problems. Your problem might be with your DVD player software. It is hard to say.
  3. Originally Posted by yg1968
    Mine is "suppossed" to play DVD+Rs but doesn't do it very well. In fact my second drive IS a DVD+R burner.
    Using WinDVD and both play regular DVDs just fine. Only DVD+Rs are a problem.
    Texas
    What version of Windvd and what operating system? I really think your PC is the problem. I have never had a problem playing pressed dvd's vs recorded dvd's other then poor media or bad burns.
  5. Try changing bitsetting if you can.
    NEC ND3500A/G
    Unproper and proud of it
  6. Originally Posted by ccbadd
    WinDVD4 and WinXP.
    But even when I'm not using WinDVD I have a problem. I cannot even copy the files to my hard drive in explorer.
    I have the same problem on my second computer which also has the same HP DVD+R 300i Writer and uses Windows 2000 Professional Edition.
  7. Originally Posted by dap
    OK change my bitsetting on what?
    I'm kinda new to some of this.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You cannot use the word professional and Memorex in the same sentence...Memorex have a better than 50/50 chance of being total garbage discs....and since you said play "all the way through with no errors" in the above sentence...it is highly likely a media problem like.... Memorsux discs.
  9. DVD+R is reasonably compatible with most modern drives. If you have a problem with a burnt +R disc, especially even on a +R writer drive, there is probably something wrong with the disc itself ... or a problem with the compatibility between the media and the drive that burnt it.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  10. Originally Posted by hech54
    So what is a good one?
  11. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Tao Yuden discs - any that say "MADE IN JAPAN". At least that's the general consensus here on this forum
    Kevin
    (I know SOME Fuji blanks are that type but must say JAPAN on them - right next to the barcode is where the country of manufacture is listed)
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Taiyo Yuden from Rima.com - I've also had great luck with Ritek...the naked shiny top ones.
    I bought naked Taiyo Yuden's as well...never had a failed burn with a naked DVDR.
