Hi,
I recently received my epson r200 printer, and I bought hub printable DVD-R's from Imation (that brand always worked well for me). Well, I usually use 4x DVD-R's - but these are 8X dvd's. I have never downloaded a firmware update (had my dvd burner for 2 years) - however, I just found out where to get one - so i'm going to do that right after this post. What I did first, was copy a movie that I had made with a Memorex 4x DVD-r onto one of these blank dvd's - it looked fine - but at the end it got choppy - does this have anything to do with the burn speeds? Are they that much of an issue when it comes to copying? do I have to set the same speed? Also, I have 2 Sony DVD-RW's that have no speeds listed on them - what I always do is make the movie to an RW first - and then copy to the DVD-R - will this be an issue now? or am I totally lost?
Then, I made an original movie with my dvd authoring software - and it came out great (burned to -R the first time).....and without a firmware upgrade....
I'm very confused here, obviously. any help would be appreciated.
just discover this: I had my copying software set on "Max" speed - I probably shouldn't do that until AFTER the firmware update - right? my dvd authoring program only lets you burn as fast as 2x - maybe that's why that one came out better?
I would only burn the max speed of the media. Also please complete your Computer specs in your profile.
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 17:41 -
i know this sounds stupid but...
By cthuggha in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th May 2009, 09:02 -
'Tis the season to post stupid questions...
By lordsmurf in forum Off topicReplies: 23Last Post: 22nd Dec 2008, 19:14 -
Media Centre DVD sound/stupid boyfriend problem...again!
By Joanna in forum ComputerReplies: 5Last Post: 30th Nov 2007, 19:19 -
TMPGEnc DVD Author 3 Being Stupid
By Nickhamm in forum Authoring (DVD)Replies: 8Last Post: 29th Jun 2007, 16:29
