  1. Is there a differance in ripping a Owned DVD movie vice a Rental?
  2. The DVDs are exactly the same whether you buy it or rent it...the only problem with rentals is that usually people abuse them and the DVD disc bottoms are scratched...which will make 1) ripping time slower or 2) errors in ripping
  3. the Difrence is that the one you own you can rip legaly but the one you rented you rip it illegaly
  4. Member Dhruv's Avatar
    Aug 2001
    Australia
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    But everyone still does it!
    I only dream in black & white...
    MSN: paschendale@gmail.com
  5. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    You know
  6. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>Is there a differance in ripping a Owned DVD movie vice a Rental?</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Yeah - when you own it and you put the wrong one back in the case it doesn't matter... when you rent it and you return a pornorip, its a mistake not quickly forgotten...
  7. Thanks for the replys!!! I will take the info and run with it!
