  1. Hi all
    I have a video clip, and in GSpot it says it is encoded with Xvid. But the runtime of the file is 00:00:00...
    It is an AVI file. I have the Xvid codec installed, and both WMP and PowerDVD just flashes for a split second before stopping...
    By the size of the file, it should be at least 1 hour 30 mins long,
    Can I salvage this file? Would it work if I converted it to DVD (using VSO DivXtoDVD)?
    Hong
    Noooooooobie
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. Well, normally i would tell you if it worked....
    But i deleted the file by accident...
    I'll redownload it and see...
    thanks!
    Noooooooobie
