I want to capture in realtime with the Ati Rage 128 (32 MB oF RAM)
My Pc is an old AMD Duron 750 Mhz with 512 MB RAM and 20 GB 7200RPM hard disk.
I want to capture in real time in vcd pal format (352 * 288 25fps.....)
what's the best software to capture excellent VCD in real time?
Is my CPU ok for real time encoding?
Is my card ok for vcd recording or are in the market best cards that do this?
Sorry for my english and thanks for your answers !
I've got an ATI 7500 AIW card and can easily capture to VCD using the ATI MMC software. Your pc is similar to mine so you should be ok, good luck
He's a liar and a murderer, and I say that with all due respect. -
Use the ATI MMC software to capture (see www.digitalfaq.com for decent settings). Your processor should be up to it as long as you stick to VCD and don't try anything better. Your hard drive probably isn't though, you don't appear to have a lot of spare space and, ideally. you want to be capturing to a separate hard drive.
I doubt it.
Worth a try though.
Warning: Your old MMC will NOT report frame drops.Want my help? Ask here! (not via PM!)
Minimum CPU to capture full motion NTSC video with HuffYUV?
By NJRoadfan in forum Capturing and VCRReplies: 12Last Post: 25th Mar 2012, 00:13 -
X264 / XVID realtime encoding with OTA Capture
By Frank420 in forum Capturing and VCRReplies: 4Last Post: 15th Mar 2012, 14:03 -
Best tool for realtime DV preview/capture?
By Drevin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Feb 2011, 09:28 -
FLV files as a capture format......from a DVCAM in realtime?
By Palmer Eldritch in forum Capturing and VCRReplies: 2Last Post: 10th Dec 2009, 21:41 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 17:09
