I have done quite a bit of work converting avi to dvd, but never with a file this large. I ran it through encoding with adobe premier, and it's still this big. Tried encoding with Ulead Studio 7 and converted it to an mpg file, and it still comes up 6+ gb. I know that dvdshrink can shrink movie files, but I'm not sure what to use to shrink a avi or mpg and still end up with a quality dvd. I normally adobe premier or Studio 7 to capture and encode, and then studio 7 to burn to dvd. I've dug through the forums and can't seem to find exactly what I need to fix this. I'm sure it's something simple. Any help would be appreciated. I've googled and seen that dvdcrypter will do this, but I can't figure out how.
Rob
Author it first then use DVD Shrink or convert it again using a lower bitrate www.videohelp.com/calc
He's a liar and a murderer, and I say that with all due respect. -
No. Do a proper encode with a dedicated mpeg encoder like TMPGEnc, MainConcept, ProCoder or even free QuEnc. Use a bitrate calculator to find what bitrate to use, to make your mpeg fit a DVD. Encoding to some random bitrate, then fixing it by transcoding (DVDShrink) is never the best option, specially if you have to encode to mpeg anyway.
And to author, there are a # of good apps like TMPGEnc DVD Author, DVDAuthorGUI, DVD-Lab...
/Mats -
Thanks.. I'll try that. I'll have to do some searching on how to calculate the bitrate, but at least I know what I need to look at now.
Rob -
Originally Posted by harley2ride
/Mats
shrinking a dvd file to email it
By Haopengyou in forum Newbie / General discussionsReplies: 9Last Post: 13th Jul 2010, 09:41 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
Shrinking MKV file
By Peleus in forum Video ConversionReplies: 5Last Post: 13th Nov 2008, 04:08 -
Converting & Shrinking to 1 DVD
By poppy56 in forum Newbie / General discussionsReplies: 4Last Post: 4th Oct 2008, 15:54 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
