Results 1 to 21 of 21
  1. only_emo_kid
    Guest
    With dvd decryptor I get around 5.6x sometimes if i'm lucky i can get 7.2x for a few seconds... Is that normal? it takes forever.. any other program is the same. -Adam ( I have dma enabled if it allows, and also latest drivers and all ) Thx
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Originally Posted by only_emo_kid
    Is that normal?
    Yes
    Drives always rip slower than they read.
  3. only_emo_kid
    Guest
    anyway to speed that up and keep a constant 7x or so?
  4. Mine rips at 2x
    Sometimes takes up to 50 minutes!
  5. Banned
    Sep 2004
    It depends on your firmware.
  6. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    also depends on the disc - I have a Lite-On 16x drive, on some discs I can sustain 10+x ripping speed, some discs average out to 3x, most around 6-7x.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Jun 2004
    California,United States
    Like housepig my results are simular. Have an old 2.4x ricoh and a 8x liteon both rip at approx the same speed. As a test even ripped 2 disks at once. Still both ripped at 6 to 10x. Until the 1st disk was done then the program Dycrpt.. didn't know what to do with the second so it stopped at that point
  8. Banned
    Sep 2004
    That is never encouraged, unless you are using two different computers.
  9. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I think I start at about 3x and max at 8x on my Liteon. my samsung was excellent till it shook a screw out of the laser!. I tried screwing it back in but snagged the ribbon cable slightly and it died
    that was a year ago and I still have it in the cupboard as I hate throwing stuff out
  10. Originally Posted by bazooka
    If your system has balls go right ahead. I do it all the time.
  11. Originally Posted by housepig
    What Houspig says.. My Lite-On rips at 6-8x normal. On some few single sided New or Very good condition used (Why Used? Cheaper of course) It has hit up to 15X+ on rare occasions Peak of course. Single sided disks usually take me 5 to 8 minutes and I figure that's OK.
    Cheers
  12. I use the Pioneer 108 to rip and consistently get 8-10x.
  13. With my Liteon 163 with updated firmware, I rip full single layer burned discs in about 5 1/2 minutes. Worst case scenario, a large 8gb commercial dual layer disc can take up to about 18 minutes to do a full rip
  14. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I have a LiteOn 166S and 167T both firmware-flashed, and peak at between 15X and 15.5X for DVD-Rs, and generally in the order of 6X - 12X for commercial DVD-5/9.
    If in doubt, Google it.
  15. Banned
    Dec 2002
    me too. my system has LOTS of balls.
    2 raids and some raptors always work well
  16. I've got 3 raptors in my pc. its looking like Jurassic Park lol
    I do notice however that the newer 74gb raptors make less noise than the 36 gb ones
  17. Banned
    Dec 2002
    I definitely concur.
  18. Originally Posted by somebodeez
    Mine rips at 2x
    You should check this page for Firmware-patches
    http://www.rpc1.com
    when your drive is sneaking at 2x
    it realy looks like it is forced to by FW...
  19. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Yup, I also have a 167T with flashed f/w.
    When I rip a single layer DVD (-/+R or video), I leave the room. I always have the feeling that the computer will explode
    Kind of noisy, but fast. 5 min for a single layer, under 15 for full double layer.
  20. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    depends on the condition of the original, but usually 5 - 8.6x on my NEC2500A with 2510A firmware.
    Read my blog here.
  21. How do you know which version of firmware you should have/upgrade to?
