All my Minolta Z1 cameras movies are recorded in .MOV format. Unfortunately, products like pinn. studio, and other dvd authoring don't support this.
I want to make sure I don't loose any quality when I convert the .mov files. Which settings should I use when using either EO or Rad Tools ?
(or any other suggestions). I assume I should convert them to .avi ?
also, does anyone know much about "mov" formats? My camera records @ 640x480 , and 15 or 29fps(selectable). That is all I know.
thanks, zepolli
thats not much help -- MOV means its a Quicktime container and it could be any one of a 100 or so different codecs ....
all the apps support quicktime but you need the right quicktime codec installed .... check the website or manual to see what type qt it is ..
or even install quicktime (if you havnt ) and install everything in the installation (specifically the authoring bits) -- it is free and is on the www.apple.com site"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I do have quicktime installed, and can play back the files fine. But programs like studio will not let you import them as far as I know.
I did a search and it is stated that .mov is not supported by pinnacle studio. I am using 9.35. I don't see how a codec will help with this problem.
For compatibility sake, the question is more , how do I convert to perhaps avi without loosing any quality? I would rather have them in a different format than .mov anyway.
thanks for the reply though.. -
pinnacle studio supports quicktime -- but you have to encocde it to mpeg2 for dvd (is this what you mean?) ..
just go ahead and encode it using a dvd template ... you can use tmpgenc or many other encoders for this --
see guides on the left for quicktime to mpeg2 conversion"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Work you bloody thing....
Ok. It looks like TMpgenc will do it or Tmpgenc Express.
How about this one?
http://www.eo-video.com/
I tried it this morning and seemed to work well. Anyone else using EO Video for conversion from .mov or anything else.
Thanks for all the suggestions.
zepolli -
Hello again,
Good!I tried it this morning and seemed to work well
However I tried EO-Video on a MOV that used a DVD-like menu structure at the start of the movie (directors comments, play, directors cut etc) and it totally screwed the Audio sync - as did everything else APART from TMegEnc Xpress!
This is why I chose to say use TmpegEnc - as a sweeping statement (EO-Video did work for me on non-menued MOVs..)
Anyway, whatever floats your boat, so to speak!
Cheers,
AndyWork you bloody thing....
Books on subtitling - Practice and Theory
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 11th Mar 2012, 12:33 -
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 06:10 -
Best Practice with ADVC-1394
By kjfrey55 in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 01:15 -
.mov to DV conversion
By aaron_rip in forum ffmpegX general discussionReplies: 4Last Post: 3rd Jul 2007, 16:55
