Hi,
I have 2 questions here, hope sb can answer:
1. I have an AVI file, it plays one audio language in Left Speaker and another in Right Speaker simultaneously. I have to switch off one speaker to listen. Now I want to recode the audio to 2 audio tracks that each track contains one language only. How can I do that?
2. After I demux audio/video, and create 2 new audio files, how can I remux video and 2 new audio files together? I do not know whether VirtualDub can do or not.
I don't know about remuxing two audio racks into an avi, however seperating the tracks is easy.
Demux your audio so you have a single stereo track. Call it Audio A. Make a copy and call it Audio B. Load Audio A into your Audio editing software. Highlight the left channel only, copy it, then paste it over the right channel. If you are asked to mix/blend it, say no. Play it back and make sure you get the same from both channels. You now have a 2 channel mono file.
Repeat the same for Audio B, but this time copy the right channel over the left.Read my blog here.
VirtualDubMod would let you add 2 audio tracks, but there aren't that many players that will let you select which audio track to play...
/Mats -
Thanks. I separated the audio and tried Nandub and VrtualDubMod to make new movie. Media Player Classic is able to let you choose audio streams. I aslo find that Divx Player can do as well.
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
6 channel audio gets mixed up during a point in movie
By Event3horizon in forum Authoring (Blu-ray)Replies: 6Last Post: 17th Jul 2010, 19:49 -
DVD with two audio channels
By Anurag in forum DVD RippingReplies: 6Last Post: 20th Apr 2009, 00:15 -
Help! Audio on DVDs plays wierd. Incorrectly Mixed?
By rayden54 in forum Software PlayingReplies: 4Last Post: 18th Sep 2008, 22:57 -
Seperating Audio Channels.
By vodmare in forum AudioReplies: 7Last Post: 14th May 2007, 16:33
