I wanted to have an intro to my menu. Play a video clip and then jump to the main menu where you have "Play Movie" "Special Features" and "Select Scene". Is there an easy way to do this?
Results 1 to 16 of 16
Yes, just have your intro video as the '1st play' item Then have it go to your main menu. Use the connections window to set all this up.
There are 10 kinds of people in this world. Those that understand binary... -
so how do you make it so its first play? like where would i load the clip into to make it play? IN VTS? im only new at this this will actually be my first time. so bare with me
Originally Posted by thedown90Originally Posted by bugsterThere are 10 kinds of people in this world. Those that understand binary...
Movie 1 is your intro.
Movie 2 is your main movie.
Movie 3 is your features.
Menu 1 is the firstplay, autoplay, timeout 0, force select button 1, force activate button 1, to movie 1 to play the intro, then jump to menu 2.
Menu 2 is your selection menu for Play Movie, Special Features, and Scene Selection.
Special Features is menu 3, Scene selection is menu 4.
Cheers, Jim
My DVDLab Guides -
Nice post reboot, that should help him more than mine did!
All he has to do now is decipher the little black, blue, and red lines to follow the linking
Cheers, Jim
My DVDLab Guides -
You're welcome
A couple of things to remember, all your video must be the same resolution, and audio all the same. Don't mix mp2 with AC3 or LPCM.
Of course, if you're doing this in DVDLab Pro, then you can mix anything you want, providing all the same stuff is in the same VTS. Use multiple VTS instead of just standard menus.Cheers, Jim
My DVDLab Guides -
Now im not sure i understand the VTS. I have just created a menu (Title, and a Scene Selection) I have 6 Videos on this DVD all under the same VTS...Atleast thats what i think it is. Also maybe you could help me... I want a play all button how do i set it up so that when you press play all it would play all of them one after another? Also if my DVD is lets say 5GB i compile it and everything with DVD-lab Pro. Can i then run it in DVD Shrink to make it fit on a DVD? Do you recomend this?
Thanks -
Also im not to sure how you got this stuff?
autoplay, timeout 0, force select button 1, force activate button 1, to movie 1 to play the intro, then jump to menu 2. -
Menu 1 has a play movie button, that links to movie 1, movie start.
Menu 1 also has a link to menu 2 (your scene selection menu).
Movie 1 is linked to movie 2, to movie 3, etc.
The connections tab looks like this:
Heh...the VTS ROOT is just the link that goes to your Intro. You want the intro to play before anything else, so it has one button (invisible all) that is selected, and activated to go directly to the intro.
After one of your movies has finished playing, it will go back to the main menu, and NOT play the intro again.
You only see the intro if you stop, and restart the dvd, so between selections (play movie to end, back to menu, change to go to features menu) you don't have to sit through the intro again.
Of course, if you WANT the intro to play after the movies have played, link the two movies (movie 2 and 3) back to the VTS ROOT, and not to Menu 2.
Yes, you can use shrink after it's compiled so it fits on dvdr.
Clear as mud?Cheers, Jim
My DVDLab Guides -
last question, how do you get the red lines to come from menu 1?? i got them from menu 2 but i dont know how i got them!
I cant seem to get a Play All button to work!! sorry to be a hassle but it just wont work.
I think i got it i had to add a VMG menu and then add a bridge!?!?! it worx!! Thanks again
DVD Title display on player LCD screen
By DRP in forum Authoring (DVD)Replies: 5Last Post: 9th Mar 2010, 13:36 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
DVD Lab - Movie/Title order in connections view
By BeachNut in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 17:17 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
