    Mar 2004
    Israel
    Hi!
    i have a movie of a few hours which i wanna change into a very shorter video by sampling every few seconds or even minutes (something like a security cam) i only need a frame every few seconds? how can i do it?
    can i get the output as a movie, or just still pictures?
    thanks,
    Tzvika
    With all due respect... and there is respect...
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    use decimate in virtualdub or avisynth ..
    you can chop it and decimate the number of frame to any amount
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    in virtualdub, it it listed under 'frame rate'
    Mar 2004
    Israel
    thanks, it does the job but not the way i intended.. it leaves the movie in it's original length simply changing it's fps - i need to also reduce the movie's lenght - keeping the same fps... ?
    Dec 2004
    Australia
    Try AVISynth's selectevery() filter. You could also add assumefps(original fps) after your other filter.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    no no -- use decimate
    Mar 2004
    Israel
    i did exactly that - decimated by a 100 and got a file exactly the same time length with each frame "freezing or about 4 seconds - than it jumps 100 frames forward... is that option suppose to also shorten the movie time ?
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    you didnt encode it yet -- just trying to watch it in vdub ..
    save it out as a new file
