Clips captured at 704x576 I want to author as 352x576. Can I just encode the 704x576 avi into 352x576 mpg, or is there something more I should do?
Results 1 to 13 of 13
Nope, that's about it!
/Mats -
Since it is 704 x 576, just load your source to your encoder and set the output direct to 352 x 576.
This framesize is the easiest to downscale with minimum picture loss, since any encoder with bilinear resizing gonna drop each second horizontal "line" (dot, pixel, call it whatever you wish).La Linea by Osvaldo Cavandoli
Originally Posted by SatStorm
/Mats -
Convert 704 to 352 horizontal lines.
The vertical lines remain 576
That way you drop each even horizontal line (or call it whatever you wish)
704 to 352 is the only scenario that nearest neighbor actually don't mess the picture.
352 is exactly half 704La Linea by Osvaldo Cavandoli
Why drop every odd line when you can combine it with every even line? Seems to me a bilinear would be better than a nearest neighbor.
Darryl -
source: black white black white black white black white...
half size nearest neighbor: black black black black black...
half size bilinear: gray gray gray gray gray... -
Originally Posted by junkmalle
Darryl -
What about using lanczos resize or precice bicubic in this situation? Would that be worse than bilinear?
I thnik it would be sharper at least but on the other side if you are encoding at low bitrates the quality may become better when using a soft resizing method.
There are other things you can do also, like replacing borders that are hidden in the overscan area of the TV with black, and to do this optimal you should do it in sizes of 8 pixels (like 8,16,24 or 32 pixels borders).
As an example:
First crop your 704x576 source to 672x544.
Then resize 672x544 to 336x544.
Last you add 8 pixels of black borders to left and right side and 16 pixels black border on top and bottom.
Now you have a 352x576 picture with black borders around thet you probably not will be able to see when watching it on TV.
OK, but why doing this if I can't see it, you may say? Well why waste bits on things you can't see. You will get a little bit better quality at the same bitrate, or the same quality at a lower bitrate.Ronny -
Whatever...
I always use lanczos when I resize from more to less. And I always frameserve!
BJ_M few years ago told me that tip while you use TMPGenc: Capture 704 x 576, encode at 352 x 576. TMPGenc resize only bilinear and 704 to 352 is the only scenario that TMPGenc actually does a good job on resizing horizontally.
junkmalle said about nearest neighbor. I first wrote about bilinear. I don't even understand How I fucked up that post on later replies. Sorry (but those things happens when you work and answer the same time)La Linea by Osvaldo Cavandoli
Satstorm
As in most cases, your replies seems to be most straight forward. Plus, from experience, your advise always work. Thanks.
What's the best way to Convert 704 to 720? Avisynth or otherwise
By VideoFanatic in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 02:19 -
Resolution problems when converting with FUW
By Malicious in forum DVD RippingReplies: 1Last Post: 8th Aug 2008, 01:02 -
704 x 576 Resolution in Premiere
By Haz567_a in forum EditingReplies: 5Last Post: 23rd Jul 2008, 05:01 -
Converting resolution size
By Illusionist in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2008, 01:38 -
704 vs. 720 burn to DVD
By brstephe in forum Authoring (DVD)Replies: 20Last Post: 11th Dec 2007, 12:16
