Hi --
I had an LG GSA 4040-B. Used it for 11 months and burned a few hundred DVDs when the drive slowed down -- took 45 minutes to burn a disc instead of 15 minutes. I figured the drive could only handle so much. LG sent a replacement drive -- a brand-new 4120 -- and the same thing has happened after only 4.5 months. I haven't burned anywhere near as many DVDs on the replacement drive.
Has anyone else had this problem? Is there anything I can do to fix it? LG is no help, as it's been more than one year since my original purchase date. I'm a bit peeved, though -- shouldn't the new replacement drive work for at least a year?
Aargh!
Short answer yes and no.
Example: If we were to track 100 cars of your favorite make and model from the factory to the junkyard. Even if they were made sequentially they would all varying lifespans due to usage, excluding accidentt, in the real world.
With relation to your drive?
Was the replacement a new drive or a refurbished ? Are you certain it was new? It was probably a discontinued model after 11 months. They have no obligation to give you a new drive as I understabnd it, stinks ? Maybe? -
I had a similar incident with an LG drive. My GSA-4040B simply stopped burning altogether after about six months. Had it replaced with the GSA-4120B, and so far I have never had a problem with it.
I would contact someone at LG and explain to them that this crapping out of two drives in a row after less than six months a piece is making you very hesitant about buying anymore LG product. Unlike a lot of companies, LG seem to understand that positive experiences promote return sales, or at least that has been my experience."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Thank you! Thank you! Thank you!
Yes -- the drive was in PIO mode, and not DMA. The LG tech on the phone didn't suggest checking this.
I followed the instructions at
http://sniptools.com/vault/getting-back-to-dma-mode-in-windows-xp.htm and that did the trick! The drive is working as fast as it should now.
Thanks again!
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
Computer slowed tremendously
By jyeh74 in forum ComputerReplies: 46Last Post: 23rd Dec 2009, 15:27 -
rca dvr dvd burner problem
By ziggy919 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 1st May 2009, 20:38 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 06:09 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
