Using ffmpegx 0.0.9s, when encoding AVI file to DVD 16:9 with manual letterboxing, final aspect ratio is way off target (stretches vertically with padding top and bottom). Anyone else finding this?
When Decoding with Quicktime everything OK (just takes twice as long!)
Also, when trying to passthough Dolby Digital audio using ffmpeg engine, it appears to export audio track as WAV and then gives an error in Terminal...
__________
If I'm not back in 5 minutes.....
Just wait longer.
__________
Your letterboxing issue sounds like it could be the same thing I've been seeing.
Try redoing your encode with a small clip to test. Leave all your settings as before, but turn off Normalize audio in the audio tab. What makes me think you have Normalize on is that normalize does a wave export before encoding to ac3.
My issue was with 4:3, but take a look at my second post here:
https://www.videohelp.com/forum/viewtopic.php?t=254731
Hope this helps,
Alph
Premier CS4 and letterboxing?
By beavereater in forum EditingReplies: 2Last Post: 28th Dec 2009, 22:42 -
Convert 16:9 to 16:10 with letterboxing hardware
By JesterMania in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Dec 2009, 15:29 -
Letterboxing video for youtube
By cwy in forum Video ConversionReplies: 5Last Post: 2nd May 2008, 09:35 -
Beginners guide to letterboxing on a PSP
By pollus in forum ffmpegX general discussionReplies: 0Last Post: 20th May 2007, 03:15 -
removing letterboxing on MPEG2 files
By hellsaviour in forum MacReplies: 3Last Post: 13th May 2007, 15:17
