Is it just me ?? or is there something wrong.
Video bitrate is now 1265 default - when i add a dvd movie,
and video parameters are 640x352 ??? autosize 16;9
In the old version, bitrate was about 2300 !
"720x576 is TV non square-pixels size. "
what do you mean with non square-pixel size.
"It should be converted to 640x352 square pixels for viewing it in 16:9 ratio on your computer. Best bitrate for 640x352 is 1265. And if you crop it will be 640x272 with 2.35:1 aspect ratio."
Sorry - but best size for 16:9 pal tv is 720x400 !!!
The bitrate, most be about 2300 - to get highend picture quality.
Please correct me ! if im wrong
720x576 is a proper PAL 4:3 size. So, it sounds like your source is a 4:3 PAL movie, and you want to crop it to a 16:9 ratio. Correct? The reason for 640x480, is because that is the proper NTSC 4:3 size (square pixels), and 720x480 would be the proper NTSC 4:3 non-square (rectangular) size. Now, for a DVD, even for PAL I believe, you would want to crop, and set your size settings to 720x480 with the DVD 16:9 option set. Even though you will be encoding to 720x480, which is not a 16:9 ratio, by setting the 16:9 option in ffmepgX, it will display at 720x404, and play back anamorphically on a DVD player. As far as bitrate, yeah, just manually set whatever bitrate you wish to use to maximize your space.
A ffmpegX's problem about setting the audio bitrate
By lzero1319 in forum ffmpegX general discussionReplies: 1Last Post: 7th Apr 2012, 08:44 -
TMPGEnc Plus not processing to specified parameters!
By Thommers in forum Video ConversionReplies: 5Last Post: 16th Dec 2009, 00:21 -
What's the best parameters for the OTHER settings in Ripbot?
By FTW in forum Blu-ray RippingReplies: 2Last Post: 21st Nov 2009, 12:08 -
MP4Box parameters for HTTP FastStart
By Wakewatcher in forum Video ConversionReplies: 0Last Post: 29th Dec 2008, 16:25 -
...setting webcam's parameters programmatically
By alexjep in forum ProgrammingReplies: 0Last Post: 12th Dec 2007, 11:36
