  1. I am trying to backup some of my DVDs and occasionally I get a few stutters. Could this be with programs/utilities running in the background? I have created a new profile which has virtually nothing running, but when I tried to backup a DVD I get the following error messages.
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 28/05/2003 18:53:46
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22/07/2004 17:33:44
    Nero API version: 6.3.1.20
    Using interface version: 6.3.1.4
    Installed in: C:\Program Files\Ahead\Nero\
    Application: ahead\Nero - Burning Rom
    Recorder: < VOM-12E48X> Version: 100D - HA 0 TA 0 - 6.3.1.20
    Adapter driver: <atapi> HA 0
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    === Scsi-Device-Map ===
    CdRomPeripheral : VOM-12E48X atapi Port 0 ID 0 DMA: Off
    CdRomPeripheral : SONY DVD-ROM DDU1613 atapi Port 0 ID 1 DMA: On
    DiskPeripheral : ST3200822AS atapi Port 1 ID 0 DMA: On
    DiskPeripheral : ST3200822AS atapi Port 1 ID 1 DMA: On
    === CDRom-Device-Map ===
    VOM-12E48X E: CDRom0
    SONY DVD-ROM DDU1613 F: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    I was using DVD Shrink with Nero 6.3 if this helps.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    What exactly are you having trouble with, ripping, encoding, or playing?
    Google is your Friend
  3. It's sorted now thankyou. It has been fine since using DVD Shrink and Datawrite media.
