I have a ton of these video files on a Mac computer and I burned them to a disc and then I brought them up to my new computer which has windows xp on it and at first the files would not play in windows media player but i downloaded a whole bunch codes decompressors and then it worked when i played it on it. But it does not work on TMPGenc or Virtual Dub. TMPGenc says file is unsupported and virtual dub mentions something about decompressors. I would like it if I can get both programs to work for these files. How can I make them work?
yo,
More info needed. What are 'these video files' - i.e. what type of video & audio do they contain?
MOVs?
AndyWork you bloody thing.... -
When VDub complained about a missing decompressor. It should have said what one. Sounds like they are avi's though, which I would have thought a little odd for a mac.
yes these are avi files downloaded from a mac,burned on a disc and copy onto my hard drive on my computer whichs has windows xp. Virtual Dub pops up this exact message " Couldn't locate decompressor for format "XVID" (Unknown)uires Videos for Windows (VFW) Compatible codec to decompress video. Direct show codecs, such as those used by windows media player, are not suitable"
GSpot is a very handy addition to your toolbox for seeing what codecs you need for given files. As for the unsupported error, if installing the right codec still doesn't work, https://www.videohelp.com/tmpgenc.htm#problems might have some useful information.
If in doubt, Google it.
EZCap & VirtualDub
By byair74 in forum Capturing and VCRReplies: 9Last Post: 5th Jan 2012, 07:35 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
VirtualDub & VirtualDubMod Error Messages..R & R
By sandman423 in forum EditingReplies: 4Last Post: 18th Oct 2007, 05:30
