Just got a new computer to add to my editing process, so using two pc with one monitor/switching and all the good stuff.
Using tmpgeditor when i go to output the edited file it is saying that my hard disk9s) have not enough space, when I have two raid disks with 136 gb spare on each!
They are set up as seperate drives not in an array or anything, like my other pc.
Why is this happening!
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Are your drives formatted for FAT32 or NTFS ? In FAT32, you are limited to a 4GB file size. Is your source file 4GB ?
thank you, why would someone put together a pc these days and use fat 32!
I suppose my only option is to re-format?PAL/NTSC problem solver.
I believe WindowsXP will let you convert to NTFS without reformatting. But be advised it is a one way process - once to go NTFS you can't go back to Fat32 without refomatting.
why would i want to!-many many thank I thought I was going mad!
I can't think of any good reason, but I just wanted to make sure you knew just in case.Originally Posted by victoriabears
New to Was Editor
By HoosierGuy in forum EditingReplies: 5Last Post: 23rd Jan 2011, 18:52 -
AVS video editor text problem
By ginny02 in forum EditingReplies: 1Last Post: 15th Aug 2010, 09:14 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 20:01 -
Codec problem (maybe) -- Hauppauge & nanoPEG editor
By SpaceCowboy9 in forum Capturing and VCRReplies: 4Last Post: 20th Mar 2008, 11:49 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2007, 00:10
