    Jul 2001
    Maryland
    I have some mac cd images, how can I burn them to cd with my mac.
    I dont use mac's, im using the one at work. what programs do I need?
    Is there a guide
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Depends on the image type. Whats the file name?
    Also depends on what mac OS you have.
    If OSX then either Toast or the OS itself should be able to handle it.
  3. Hi, what type of disk images do you have .iso or .dmg? and what Mac OS are you using MAC OSX 10.x.x? or OS9?
    The Mac OS has a built in utility called 'Disk Copy' this will burn a disk image to CD, depending of course what type of disk image you have.
    If their are files i.e an application that you wish to install from the disk image or simply access data, have you tried to mount the Disk Image to the desktop?
    Jul 2001
    Maryland
    i have both dmg and toast images and Mac OSX
