OK, strange problem...
I have a home made movie that I put on DVD. Everything plays PERFECT on a standalone and also on a computer. When I try display the video through an LCD projector, the portion of the screen where the video is playing doesn't display on the projector. It's still playing on the monitor, but no projector. I can move the mouse over the video and see the mouse pointer, but still no video.
Standalone DVD player to the same projector works fine.
I tried this on two laptops, same result, I thought I turned off hardware acceleration, same result. Full screen, windowed, etc. The portion of the screen where the video should be playing is just black.
Any thoughts? I normally wouldn't play the video through a computer through a projector, but in this case I need(ed) to.
The program I was using was WinDVD.
Have you selected the correct video out in display settings?
Originally Posted by jimmalenko
Originally Posted by Bodyslide
If I hook up a DVD player to the projector, it plays fine (although I lose some of the screen due to the overscan). THe projector is set on RGB mode for the laptop and Video In (RCA) for the DVD player. Also work on S-Video. I'm thinking its NOT something with the projector, it's got to be something with the way WinDVD is rendering the DVD image, however why the projector doesn't just display what's on the screen is beside me. -
Not strange, I had the same problem with my projector using Zoom Player. Everything but the video would display. VLC player would work, though. I reinstalled Zoom and it works fine.
You may have to adjust your overlay settings when the projector screen is being used. On my setup they are not all available when using the computer monitor. Try a different software player, also.
If all that fails, study your video card instructions. Somewhere in there is probably the solution. -
OK, I'll check for the overlay settings. I'm sure I'll see something if I go into the setup.
At home I use PowerDVD, work uses WinDVD. We did try Microsoft Media Player as well, not sure which version.
I'll take another look I guess. Overlay seems to be something I didn't check, although I still don't quite understand. I'm sure if I go digging, it will make sense.
Windows Explorer Doesn't Display Certain AVI & FLV Thumbnails
By ezehelm in forum ComputerReplies: 1Last Post: 4th Nov 2011, 15:20 -
Any benefit in Feeding HD signal to a Non-HD Projector/Display?
By Soundster in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2011, 11:18 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 00:36 -
VLC problem - doesn't display full length, only plays bits...
By MikeMGMVE in forum Software PlayingReplies: 3Last Post: 3rd Sep 2008, 14:38
