why do you get a better spec board with amd than intel eg one ide and four sata on new boards (intel) amd two ide and four sata or four ide, two sata??
Results 1 to 12 of 12
An example of two such boards would be helpful. You can find either an Intel or an AMD socket board with a huge variety of specs although I have never heard of a motherboard with only one IDE channel.
If what you are saying is some kind of solid rule, then it would be because there is a chipset that exists for AMD that supports said feature and such a chipset for Intel does not exist. -
intel MSI 925XE Neo Platinum
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH6R.
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
Amd MSI K8N Diamond
• An IDE controller on the NVIDIA nForce4 SLI chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
both are from MSI has you can see
and spec from ccl (computer retail near me )
for Abit AA8XE 3rd Eye (intal 775)
http://www.cclonline.com/product-info.asp?product_id=2189&category_id=251&manufacturer_id=0
and amd MSI K8N Neo2 Platinum (socket 939)
http://www.cclonline.com/product-info.asp?product_id=1763&category_id=252&manufacturer_id=0 -
I don't get your meaning. I went to Newegg quick to look at two Asus boards priced at ~$135 and came up with the A8V Deluxe socket 939 board and the P5GD1 socket 775 Intel board. AMD board has 2x IDE and 4x SATA, the Intel has the same. Only difference I could see between the two feature-laden boards is the Intel board supports PCI-E and the AMD board has onboard 1394. Kind of a toss up there IMO. Both are actually a great deal for the price, I thought.Originally Posted by AMD Fanboy
Summation: Asus makes great mainboards!
FB-DIMM are the real cause of global warming -
If you've got the money, go for SATAII (max throughput of 3Gbps).
Nothing can stop me now, 'cause I don't care anymore. -
Check Out This ASUS Mobo for Intel - 8 SATA Connections !
http://www.newegg.com/app/viewproductdesc.asp?description=13-131-516&DEPA=0 -
well looks like i do not understand intel spec like i do amd
Check out my motherbaord, also 8 SATA connections, with 4 of them being SATA2 (3GB/s).Originally Posted by Soopafresh
http://www.asus.com/prog/spec.asp?m=A8N-SLI%20Deluxe&langs=01 -
It looks like you are comparing two entirely different levels of Mobos. Of course, a lower priced Intel board will have less than a higher priced AMD board... then again, I really don't know what boards you are comparing and the price of each. Your whole question is just ridiculous as is.
What's ridiculous is that you didn't even bother to read enough of the thread to see that he posted the names of the two boards he is comparing and detailed specs.Originally Posted by smearbrick1
Amd MSI K8N Diamond
http://www.cclonline.com/product-info.a ... turer_id=0
http://www.cclonline.com/product-info.a ... turer_id=0 -
Sorry... noticed the comparison. Didn't see a price comparison. The Links he/she provided do not work. I maintain my original position.
they are top of range boards and the link do's work,the link boards are at the £100+- @price,or look at
and
http://www.cclonline.com/product-info.asp?product_id=2191&category_id=251&manufacturer_id=0
HP Laptop help (Is Intel motherboard worth $200 more than AMD?)
By jyeh74 in forum ComputerReplies: 9Last Post: 13th Dec 2009, 16:48 -
Intel 850 motherboard help
By frieday in forum ComputerReplies: 6Last Post: 12th Oct 2009, 14:27 -
AMD or Intel
By waheed in forum ComputerReplies: 33Last Post: 4th Mar 2008, 15:43 -
AMD or Intel??
By caesarhawy in forum ComputerReplies: 15Last Post: 13th Oct 2007, 23:47 -
Intel New Media Series Motherboard
By jmbadu in forum Media Center PC / MediaCentersReplies: 0Last Post: 10th Jul 2007, 23:23
