The disks I have are TY's and they have a shiny silver top. I found a sharpie permanent marker in my desk but i'm not sure if it's safe to use on these disks. What do you recommend?
Results 1 to 26 of 26
Any felt tip is OK I use SHARPIE no problem just make sure they are dry before stacking,
Sharpie is the classic default although they won't warranty digital media.
I made that mistake once, it caused some playback problems until I spotted the ink on the bottom side and cleaned it off with some toothpaste.Originally Posted by doppletwo
"Art is making something out of nothing and selling it." - Frank Zappa -
Staedtler permant lumocolor.I've been using them for 2 years,no problems.
bmiller,ont.canada -
Sharpie
Fine point sharpie has worked great for me.
Over one thousand DVDs written on and no issues yet.
Dan Ginnetty -
Wow. What happened? This used to be as fun as the +/- debates... Where's the anti-sharpie people?
I use a ballpoint Bic. Have to go over it a few times when the top is shiny. I would say the merits of the ballpoint are greater than the Sharpie.
1) No "headrush" from the magic marker smell
2) I can buy a ten pack of Bics for $1.00 on sale. Sharpies cost over a dollar EACH !
3) The thicker point of the Sharpie almost always assures that the letter "e" and "a" can get filled, skewing and confusing the reader.
4) Leave a Bic in front of a running air conditioner. Now take the cap off the Sharpie and leave it in front of the air conditioner. In four hours, which instrument will still be able to write ?
I'd say the ballpoint pen wins hands down. -
Well, my original vote was for the dremel tool.
But I will have to say a fine point Sharpie has been working great for me for 2 years now. -
Sharpie.
Maxell included a "Media Marker" with a 15 pack of their RG03 disks and it's terrible. Barely shows up. Sharpie is nice and dark and you can actually read what you wrote on the disc! -
Originally Posted by Soopafresh
I was always told and have learned from experience that you should never use ball point pens on media. They work great until you press just slightly too hard and cause label side damage on your media just after you burned it.The real answer lies in completely understanding the question! -
If I recall, for CD's this was an issue. For DVDs not as much so, the dye that is burned is embedded between 2 layers of plastic, where CD's place the dye on the backside of the top label.Originally Posted by Tidy
Still I agree with you, I wouldn't recommend ball point pen. -
I use a sharpie or other perm marker. Bic makes one that is pretty good as well.
I do have to admit that I learned this from CD media and thinking about it DVD may be different but with a sharpie you take no risks. As for leaving your pen in front of the air conditioner with the cap off seems to me a good solution is put the cap on HAHAOriginally Posted by BSR
Sharpie Ultra Fine Point
A wooping $1.29 for this fine writing instrument. Think of a sharpie with a 1 mm tip.... nice 8)Features & Benefits
Marks on most hard-to-mark surfaces
Permanent on most surfaces
Fade and water resistant ink further extends multiple project uses
Extra precise narrowed tip for extreme control and accuracy
Slim barrel design for easier storage
Metal pocket clip - never misplace your Ultra Fine Point!
Quick drying, non-toxic alcohol based ink formula
24 assorted colors to make your marking unique
JSB
PS don't forget to put the cap back on....
Ooops, that is what I use, with the itsy bitsy tip, works great.Originally Posted by JSB
Sanford Sharpie Xtra & Ultra Fine Markers
Resilient tip produces a quick ink flow that dries fast, resists water and stays permanently.
Xtra Fine and Ultra Fine tips.
Quick drying.
Water-resistant, permanent ink.
Nontoxic.
Sanford Ultra Fine Point Permanent Marker
Series No. 37000 Black
Buy them by the box of 12 about $9 -
Sorry guys, I was trying to be funny....Must not have translated properly.
Just for the record, I'd NEVER use a ballpoint pen on a DVD or CD. -
I use the EXTRA ... the ULTRA dry up too fast
Yeah the ultra dry with the cap on you have to get the ink flowing again every time.
I just use the normal sharpie my writing looks like chicken scratch no matter how fine the tip is.snappy phrase
I don't know what you're talking about.
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 13:38 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
time marker in mov, or mpeq4?
By mias in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 06:33 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Using ARROW/MARKER to pin point a figure in your video!
By godsownson in forum MacReplies: 5Last Post: 10th Dec 2007, 22:12
