Hello,
I have a DV camera and I use a firewire card to capture the video. I was wondering if I could some tips on what to with the video files, since they take up so much disk space (besides burning DVDs, because I would still like the original video that was captured). Some options I have considered: burning the raw AVI to a CD-RW (not a VCD), burning the raw file to a DVD (again, not DVD video). If there are some better ways please let me know.
Hi patrickmerrill,
DV AVI takes up around 13.5Gb per hour. So storing on CDs, or even DVDs, as data means you'll need a lot of disks for not much footage.
Get yourself a 200Gb hard drive, possibly in an external housing so it can be easily "moved around" or stored. Large hard drives aren't that expensive nowadays...
Some people export their finished projects back to DV tape and store them that way.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
thank you, i think i will just keep a miniDV tape or 2 around to store my video on...
thanks again,
patrick
Batch screenshots w/ rendered subtitles?
By adam.skinner in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2011, 09:38 -
cpu's about to be rendered obsolete...
By deadrats in forum Latest Video NewsReplies: 7Last Post: 11th Jun 2011, 13:16 -
Lines on my rendered videos?
By Tahlos in forum Newbie / General discussionsReplies: 30Last Post: 23rd Jun 2010, 18:35 -
edit studio 6 jerking rendered material
By mistressa in forum EditingReplies: 1Last Post: 8th Sep 2009, 17:38 -
Is this rendered quality OK?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jun 2009, 14:17
