Hmm, I am using a NEC 3520 and I successfully wrote a downloaded DVD-R ISO to a Verbatim DVD-R which plays fine...
I then made a copy of that DVD-R to another DVD-R (from and to the 3520) caching the disc on C: with nero... The copy does not play correctly, it bypasses the menu and freezes a few seconds into the film. I then copied the data to C: which worked (no read errors) and I tried to play it from there using PowerDVD - same problem (menu bypass and freeze). How can that be?
Results 1 to 10 of 10
But the copy back to the HD didn't complain on read error - u think the data got corrupted but still readable?
Originally Posted by RzSwede
Yep, me to =) I copied the data manually from the second disk to the HD (VOB-file copy went fine using windows explorer). PowerDVD is getting the same problem playing from the second media and from the HD... if it was bad media I would have thought the disk would be unreadable at some stage?
Sounds like an authoring error with the copy,use dvd decrypter instead to copy to the hdd,why not just burn a second dvd with the original dvd files?
I deleted the ISO file and realized I wanted another copy so I had to make it off that DVD - I'll try using DVD Decrypter and see how it goes.
Thanx -
This is strange, it's still happening, here's an update:
I managed to successfully copy the first DVD by using DVD Decrypter then writing it back using Nero to a new DVD...
But now I did the same process with another DVD, using DVD Decrypter to copy it back to the HDD, then use Nero to write it to a new DVD (at 8x which is the recommended speed for the verbatim disc, with verify on) and it successfully burned the DVD, but it freezes half way through - although after ripping it using DVD Decrypter it plays fine from the HDD and the NEC3520 hasn't produced a single coaster when initially writing ISO's, only once they are recopied like in the process described.
Anyone got any ideas?
Thanx -
Try using dvddecrypter to burn your iso images instead of nero. Easiest way to backup a copy. Iso read then iso write. Never given me any troubles.
Donadagohvi (Cherokee for "Until we meet again") -
Thanx, freebird,
I just tried it and it worked this time, hopefully that'll keep working!
Great advice(and I also see that it is in the guides so shame on me)
TMPGEnc DVD Authoring Works 4 DVD+r space problem
By gigaslackr in forum Authoring (DVD)Replies: 1Last Post: 28th Dec 2009, 13:43 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
Samsung dvd-4155 DVD Player/recorder format problem
By jamesd1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th May 2009, 22:51 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
