Would appreciate any advice. Is there a way to play a vid on my hard drive (avi,mpg,dvx,etc) using windows media player or similar and connect the output to my stand alone Panny dvd recorder? I've been connecting vcr or dvd player to stand alone to burn dvd and quality and efficiency are great. I've been using pc dvd recorder with Nero to burn dvd or vcd. However, is there some way to bypasss having to use Nero and pc recorder and move the streaming vid to the stand alone. Reason for interest is that the standalone converts to dvd format in "real time" --obviously less time than using Nero to "convert" and "burn". I believe that IF I had MS Media Center pc I could stream the pc vid to my tv, but I do not have that system.
Any thoughts greatly appreciated.
Thank you.
Can't you just use the TV-Out port (s-video) and the line outs from your sound card? And use a good media player (not WMP!).
Monzie, thank you for reply. My yr 2001 pc has a GeForce4 Ti4200G Graphics card w/ tv output(single display). I changed the setting so I could see monitor screen on my digital 8 vidcam to test output and it displayed fine. Two questions, though.When I open windows media player, the player window around the vid shows for some of the vids, even at "fullscreen" mode. In other vids, player fluctuates between full screen and then showing blue on 1/3 of right side. Can you recommend a better media player. Also, will I see a noticeable loss of resolution using this method compared to burning directly from hd to internal dvd burner?Would I be better off buying a more recent vid capture card? If so, any recommendations?
Thank you for your thoughts. very much appreciated. -
Try BSPLAYERPRO or ZOOMPLAYER, both will display full screen without a box.Originally Posted by hydrant29
We're not talking about high quality sources here, so it would probably be OK.Originally Posted by funkguy4"Art is making something out of nothing and selling it." - Frank Zappa
I think several people have mentioned they are sending edited AVI from the PC to some DVD recorders via firewire (at least the JVC is capable of this, from what I understand).
How you can use a stand alone DVD recorder and your Canopus 110
By fuzzblaster in forum Capturing and VCRReplies: 22Last Post: 3rd Oct 2010, 13:06 -
Stand-alone Recorder (video blocking signals)
By grom in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Dec 2009, 04:19 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 22:21 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 10:55 -
Looking for a Stand alone, cheap, DVD recorder, timecode on screen.
By AtomX in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Feb 2008, 17:10
