Wow. This could be a newbie question, and I apologize if it is.
I'm using Sony VMS 5.x, and I'd like to perform a specfic type of effect. I doubt it's a filter, per se... here's what I'd like to do...
Take one frame of a clip (mid-stream), and carry that frame for a few seconds (like freeze frame). After 'n' seconds (frames), have it continue right on with the rest of the clip.
What's the easiest "or (gasp) best" way of doing that?
If it's to take an image capture of the frame, I don't know what program allows me to export the target frame, and besides that, matching up the exact "splice point" might prove difficult.
Thanks so much!
how I would do it - (in Vegas 4)
find the frame I want to freeze. drop a marker at that frame, then Split At Marker - this gives me two clips from the original clip.
then I would highlight the desired frame and export it to an image file like .jpg or .png or .bmp.
then select the second clip, drag it away from the first clip, and drag the image file into the gap. expand or contract to taste.
pretty simple, at least in Vegas - but really, as long as you have the ability to split at a defined point, you could do it with anything.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Again, using Vegas. If the length of the clip can change, then I would use Housepig's suggestion. If the length of the clip needs to remain fixed, perhaps to match audio without having a blank patch in the middle, I would use a velocity envelope and drop to 0 in one frame, then back to 100% a coule of frames later.
Read my blog here.
Yeah. I don't have velocity envelope control in the "Home" version of Vegas Movie Studio...
But... I think I should have the ability to export the frame... but for the life of me, can't find the command/button.
Looking for a specific video thumbnail generator
By KaaMoS in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2012, 11:20 -
Help regarding playing specific video file in WMP
By sohaibrazzaq in forum Software PlayingReplies: 4Last Post: 25th Sep 2011, 12:19 -
Specific video card requirements for HD playback?
By GLE3 in forum Newbie / General discussionsReplies: 17Last Post: 1st Apr 2009, 12:12 -
Highlighting a specific part of a Video..? How?
By Moontrash in forum EditingReplies: 6Last Post: 14th Oct 2007, 07:04 -
Creating this specific slow-mo effect.
By rjwise in forum EditingReplies: 2Last Post: 19th Sep 2007, 03:04
