I have a Formac Studio TVR. I've actually had it for a couple of years, and all I've ever used it for is television.
If I want to copy a movie by playing it, should I use DV or Quicktime format for best results for copying to DVD?
You give a man a fish, that man knows where to go for fish. You teach a man to fish, you've just destroyed your market base.
Actually, I'd try using Toast's plug & burn feature to import using the Formac directly into Toast. Toast might not recognize the Formac as a "DV camcorder" but I know it did recognize my Canopus ADVC-55 as one.
Capturing in DV will give you the best results. That's how Toast captures the video with plug & burn.
It's unlikely that the Formac will capture video from any copy-protected source. -
I've been wanting to get my hands on a Formac Studio TVR to compare it to Canopus ADVC. The main thing it had going for it on the Mac was the TV tuner.
"I want to copy a movie" from what source? Internal TV tuner, cable box, VHS or something else? What is the authoring destination? DV is the normal choice for best quality. -
After unsuccessful attempts at ripping the DVD, I figured maybe I could just play it through a stand-alone player.Originally Posted by edDV
I hadn't thought about the copy-protection through AV cables bit. Maybe I'll give it a shot and see what happens.You give a man a fish, that man knows where to go for fish. You teach a man to fish, you've just destroyed your market base. -
It might. Unlike the ADS Instant DVD for Mac, it has no Macrovision detection.Originally Posted by FrobozzGo off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
There's a version 2.2 of PixeDV hidden in the ADS USB Instant DVD for Mac software package that ignores Macrovision. It is NTSC only.Originally Posted by mhar4
Yes, indeed. Unfortunately, I live in the PAL part of the world.Originally Posted by Frobozz
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
MPEG2 Works 4 demuxes ADS mpegs. While I do not own one to test, it sounds like it can take the vobs and give you the streams. Ou can then author a new DVD.
Anything Sony DVD Architect won't do that Pinnacle Studio will?
By brassplyer in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2011, 01:38 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Old Studio 8 won't detect scenes or audio
By BwanaP in forum EditingReplies: 3Last Post: 1st May 2009, 10:17 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 16:20
