I capatured my wedding video from my sony hi8 camcorder to my jvc dvd recorder which i then put on to dvd so i could edit it with pinncale 9. I soon found out that i had to change the vob files which after alot of messing round with programs (all weekend) i ended up with one file in mpeg
.When i put the file into pinnacle 9 it worked fine all the clips came up in the time line but it still would not play them
. Can anyone help as I have messed around with this for about 2 weeks and still not getting anywhere
i have found out that the sound is in ac3 and i dont think pinncale works with ac3
This is easy.
Extract JVC discs:
http://www.digitalfaq.com/edit/recorderedit/recorderedit.htm
Convert AC3 to PCM in Besweet.
Dump Pinnacle 9 if you can, it's usually crap.
If you have the codecs, Vegas and Premiere can import it. Free software also exists (Avid Free DV), as does MPEG editors (Womble MPEG Video Wizard).
Have fun, good luck.Want my help? Ask here! (not via PM!)
If you want to try something similar but better than Pinnacle give Ulead Video Studio 8 a try. It has a AC3 plug in.
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 13:53 -
No video only sound in the beginning of the converted file from AVI to DVD
By lankafta in forum ffmpegX general discussionReplies: 1Last Post: 21st Jul 2009, 22:16 -
converted video not apearing
By Blueduck in forum ffmpegX general discussionReplies: 3Last Post: 20th Jul 2008, 18:17 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 05:03 -
Having problems getting a MPEG Video Wizard converted/edited DVD to burn
By editup in forum Video ConversionReplies: 18Last Post: 15th Oct 2007, 22:40
