Is PCM audio from DV video a surround sound source?
Is three 6 channels to encode it to ac3 surround sound how do you know if the audios got 6 channels?
Or if i encode PCM audio to ac3 surround sound file is it just converting a stero channel audio file to a 5.1 channel audio file, and not gaining the surround sound?
AC3 itself is just a compression standard. If you have a stereo sound track then AC3-2channel will suffice. You can encode 2 channel audio to 5.1 but the other channels will be mute unless you re sample it. Programs as simple as studio 9 plus will alow you to move audio around and then encode to 5.1.
Other free tools for AC3 conversion is available as well, like besweat on some others. Other editing tools like Ulead, MyDVD, Sony Vegas Video etc can also do AC3 encoding.
The real advantage to AC3 encoding for DVDs is dvd compliancy and to save valuable space for video.
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 24Last Post: 7th Jul 2016, 07:17 -
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 08:35
