I have been playing with WinDV and finally figured out how to get the files all in one instead of multiple files, but the one AVI file has no sound, and I was sure to Type-2. I even used the guide from http://www.dvd-guides.com/content/view/33/59/ to try and get it correct.
Anyone have any other ideas on this?
When I used the other software that brought the file in as a mpg there was sound. Also when I used Windows Movie Maker like someone suggested it pulled the file in fine, had sound as AVI but when I tried to encode it as a mpg using TMPGenc the sound was terrible distorted.
"ONE BY ONE THE PENGUINS STEAL MY SANITY"
Well I guess I should have googled it before posting this. I fixed it by pressing play on the minidv cam before capture on the software instead of letting the software start the cam.
Hope this helps someone else too."ONE BY ONE THE PENGUINS STEAL MY SANITY"
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 17:23 -
WinDV - Hear sound during capture?
By scormodo in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2010, 10:41 -
Windv to harddrive
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 04:36 -
How to configure windv?
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 13th Sep 2009, 08:30 -
WinDV
By kippard in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2008, 23:43
