What is the best way to do that?
Tkz,
Simps
Convert to mpeg....you may just be able to rename them .mpg. Otherwise rip them with DVD Deccrypter. Import into editor, output as mpeg or author to disc.
Make sure you use the same video setting as the original or a editing/authoring tool that doesn't convert compliant files so you won't have to rencode providing all the the source files are the same format. -
Why would you like to do that, is the question...
The coalman is correct tho - you should extract the m2v video and ac3/lpcm/mp2 audio track(s), join those separately, and finally multiplex back as mpg. ReJig is good (and easy to use) at demuxing VOBs
/Mats
VobEdit - won't join vobs
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2012, 19:29 -
How to join 2 DVDs which results in more than 9 VOBs ?
By ffooky in forum MacReplies: 3Last Post: 11th Dec 2008, 16:19 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Are you able to join PAL and NTSC vobs together?
By ramrod1234 in forum Authoring (DVD)Replies: 12Last Post: 26th Apr 2008, 04:27 -
How to join 3 VOBs in VirtualDubMod
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2007, 11:09
