I have many avi movie files and i need to split them up to fit them onto two discs. I downloaded dvtool but it says it does not support theese files. Does anyone have any ideas? thank you very much
Just about every editing progam does that, some only support specific types of video though, try virtualdub if your looking for a free one.
How can split a mts movie file without loose the quality
By siopilos in forum EditingReplies: 5Last Post: 15th Feb 2012, 14:57 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
split one file avi in two
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 14:13 -
Split DVD into movie clips based on timing info in subtitle file.
By kwazi in forum Authoring (DVD)Replies: 1Last Post: 20th Feb 2008, 10:27 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
