No matter what I do, i get this error. Does this avc implementation not work with HD sources? That seems odd.
target.m2v ext: .m2v
Trying demuxer 2 based on filename extension
sync_mpeg_ps: seems to be ES/PES stream...
The selected video_out device is incompatible with this codec.
MPEG Stream reached EOF
ds_fill_buffer: EOF reached (stream: video)
MPEG packet stats: p100: 197 p101: 197 p1B6: 0 p12x: 3152 sli: 590 a: 590 b: 590 c: 0 idr: 197 sps: 0 pps: 197 PES: 0 MP3: 0
MPEG-ES file format detected.
==> Found video stream: 0
Searching for sequence header... OK!
VIDEO: MPEG2 1920x1080 (aspect 3) 23.976 fps 14200.0 kbps (1775.0 kbyte/s)
[V] filefmt:1 fourcc:0x10000002 size:1920x1080 fps:23.98 ftime:=0.0417
Opening video filter: [expand osd=1]
Writing AVI header...
-1=autodetect) osd: 1
Opening video filter: [scale w=1920 h=1080]
SwScale params: 1920 x 1080 (-1=no scaling)
Opening video filter: [pp=0x33]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 1920 x 1080 (preferred csp: Mpeg PES)
[PP] Using external postprocessing filter, max q = 6.
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Problems converting H.264 AVC to MPEG2
By Gwar in forum Video ConversionReplies: 8Last Post: 4th Jul 2011, 12:29 -
Problems with converting mkv(h. 264) to avi
By sgbd in forum Video ConversionReplies: 7Last Post: 18th Nov 2010, 12:10 -
H.264 compatibilty problems
By Justin123 in forum Video ConversionReplies: 18Last Post: 26th Apr 2009, 21:38 -
Problems with H.264 and Staxrip
By ndaher in forum Video ConversionReplies: 15Last Post: 4th Feb 2009, 23:48 -
having problems in converting from h.264 to avi
By the deadman in forum Video ConversionReplies: 3Last Post: 18th Nov 2007, 11:08
