Hi All, ok what ive recently done is purchase a PC to TV Wireless AV Sender so i can watch all my Media/films from my PC direct to my TV with no need for any DVD conversion, so my plan now is - rather than convert my AVI films most of which are only about 700MB to DVD resulting in a few Gig per film, to leave as they are enabling me to put about 5 films on 1 single layer disk but still have a Menu that points to each film. Now there must be some kinda software out there that creates a personalised Menu that can direct you to each individual AVI File. Thanks in advance for all who can help with this idea of mine.
Results 1 to 10 of 10
But wont your 'menu' just be the 'Open Folder to Read Files' prompt after insertion?
Well there must be some way of making the Menu AutoPlay wen you first insert the disk the same as when you buy software, a menu appears and asks wot program you would like to install etc etc
Not AVI->MPEG conversion.
Moved to "GENERAL" forum.Want my help? Ask here! (not via PM!)
Sorry could find the best section to put this under, as its kinda like Authoring but non DVD etc etc
If you burn it as a data disk, not a video disk, then any CD menu creation program should do the job. You could even do it with HTML or Flash.
Try some of the freeware sites, such as tucows, download.com or snapfiles. They will have a number of free tools to do this for you.Read my blog here.
ok, thanks for the suggestions, i will do a search for some Autoplay software and post my discovery laters, thanx again
Jay T -
No software required it's a simple text file..... http://msdn.microsoft.com/library/default.asp?url=/library/en-us/shellcc/platform/shel...play_works.aspOriginally Posted by JayT
ok - sounds good so far, so i can create a HTML document with Dreamweaver then all i need to do is create an INF/Autoplay file to point to that HTML document which will contain the MENU ive created to point at my AVI files - Thanks Guys - Time to experiment, let you know how it turns out.
Thanks Again
JayT
Avi on DVD with menu
By Regor21 in forum Authoring (DVD)Replies: 1Last Post: 20th Mar 2011, 13:58 -
Is it possible to add a DVD Menu to a AVI?
By Rayster in forum Newbie / General discussionsReplies: 9Last Post: 7th Aug 2010, 11:47 -
Avi's to data DVD menu
By capa in forum DVD RippingReplies: 2Last Post: 9th Jul 2009, 12:08 -
Burning Multiple AVI's with Menu
By Candoo in forum Authoring (DVD)Replies: 12Last Post: 8th Jan 2008, 18:52 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23
