Hi Folks![]()
My first post on this site,so hoping for a good start
I have a XVID encoded film which has a bitrate of 810 kb/s and audio
of 0x0055(MP3) ID'd as MPEG-1 Layer 3/130 kb/s (65/ch, stereo) VBR LAME3.90.°. I am playing on a ELTA 8883 standalone DIVX player.I use NANDUB to cut film into two parts ( over 700 mb in size). The audio is fine when playing but the the video IS "LAGGING" ie runs just that bit to slow!!
I used NERO 6 to write to disk.Any ideas to solve problem.
have played the following films ok on the DIVX player:
super.size.me-pg13-xvid.avi
Video = XviD,bitrate=846 kb/s,FPS=23.976
Audio = 0x0055(MP3) ID'd as MPEG-1 Layer 3
127 kb/s (63/ch, stereo) VBR LAME3.91
This played at the normal speed and had no "Lagging"
ie just playing to slow in frame speed!!
I dont know whether its the original source material?
the divx player? or the burning software,Nero?
When cutting the film I set Nandub to Video->Direct stream copy
Any suggstions would be great
Chegmasterfunk
Results 1 to 9 of 9
Are you playing it on your PC and it's lagging or on your DVD player and it's lagging, or both?
Does your player support VBR mp3? I'd suggest replacing the audio with CBR of some kind, then cut.
/Mats -
Hi Mats
I dont think so!!! How would I change the Audio from VBR TO cbr?
Chegmasterfunk -
By reencoding. Easiest would be to use:
1) Goldwave to extract audio to wav (Just load the AVI, save wav)
2) Encode wav to CBR MP3 with CDEx
3) Remux audio back into the AVI with VirtualDub
/Mats -
1) Try writing at a slow speed (4x-8x).
2) Try recoding the audio to CBR.
3) Try changing the framerate to 29fps. -
Hi Messiah289
Will try that as well!!!
Thanks Folks
Some homework for me!!!!!!
Chegmasterfunk
XviD video playback problem
By mictsekk in forum DVD & Blu-ray PlayersReplies: 5Last Post: 20th Jul 2009, 11:16 -
Xvid Playback Aspect Ratio Problem
By midders in forum Video ConversionReplies: 3Last Post: 1st Apr 2009, 15:24 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 13:17 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 08:04 -
Sound Problem During Playback (XVid, DVIX etc.)
By Pyrolisk in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:00
