Please help, can anyone tell me how to get rid of or fix coruped files &
programs .I went to open msn chat said in valid passwod so i went to help & it came up as a prgram i in staled for my neice for homework then i went to add & remove programs tryed to delete and it read
this file is coruped & it wll read cant find unintsall log on other things.
please can you help me???
im also new here so i hope im in the right place.
thank you
Uninstall MSN Messenger and reinstall
Just moved you to the Computer forum.
Ok first calm down and speak in complete sentences.Originally Posted by gokoo56
Next, try what Cap said and uninstall MSN messenger and reinstall it.
Just a thought but you might be able to just download MSN messenger again and it would overwrite the existing files.
well 1st of all just check whether the homework program u used isn't in comflict with msn if yes try 2 install it on a different OS or just delete that program or try sumthin like registry fixer for some registry problems
no authoring programs will accept my avi files
By jsdspif in forum Authoring (DVD)Replies: 11Last Post: 16th Dec 2011, 15:44 -
DVD & BluRay Menu + Chapter Creation Programs ?
By VideoFanatic in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2011, 23:06 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 08:34 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40 -
Making more room via desktop & programs menu
By Marvingj in forum ComputerReplies: 3Last Post: 31st Jul 2007, 13:26
