    Mar 2003
    Plymouth UK
    I knew this would be a bastard . I have XP Pro , SP2 , and ive had Easy CD Creator 5 Platinum on my PC for about a year . I would like to change to Nero which i have just spent £30 on . My problem is after uninstalling Easy Cd Creator and trying to install InCd the whole system crashes to the blue screen of death !!! It said something about a problem with the UDF reader .I then have to go in via safe mode and uninstall INCD . I have visited several forums but cant seem to find the definative solution . Is the UDF reader both common and compatible with both Roxio and Ahead software (Nero) ?? Is there a way to completely get rid of the roxio UDF reader which i think is causing me all the problems ?? I know someone must have gone through this at some stage and some help would be greatly appreciated . All i want is Roxio gone and Nero plus InCD in its place. Cheers guys , Steve , Plymouth UK
  2. Banned
    May 2003
    Massachusetts
    InCD crashes computers no matter what.
    All packet writing software is retrograde and should be abolished.
    Mar 2003
    Plymouth UK
    Well is there a way that i can run Nero 6 and still have a UDF reader for drag and drop copying to DVD-R
  4. Banned
    May 2003
    Massachusetts
    What you're asking for is a UDF writer, not a reader. And the answer is ... sure, but it will mess up your machine. All packet writers do, to one degree or another. I haven't run into a stable one yet.
    Mar 2003
    Plymouth UK
    Oh great , after using the Roxi-Zap utility which gets rid of all roxio files my windows cd writing wizard wont copy to a blank CDR . Im guessing its took a couple of important files with it !!! Anyone know a way around this ? Cheers , Steve
