i have tried it in Vdub, but obviously the audio and video goes out of sync. Is there anyway to convert 25 to 23.97 witout losing sync? some one help please, there are some other ppl wif this problem
It's pretty straightforward - extract the audio first, then encode the video at 23.976 instead of 25 fps.
Then using something like CoolEdit, convert the audio speed, encode it and remux it with the original - I've done this for many PAL DivX to VCD/SVCD and it works like a champ.
You can't hear the 4% change in speed (in fact, that's how PAL is normally created from FILM in the first place). -
http://www.syntrillium.com/
A free solution is to frameserve with Avisynth
AVIsource(".avi")
assumeFPS(23.97,sync_audio=true)
<font size=-1>[ This Message was edited by: Truman on 2001-12-05 16:45:55 ]</font> -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Thank you so much for your help. Very much appreciated, i always wanted to know if there was a program that could stretch the length of audio streams, or make them shorter without cutting any off. Thank you so much.
How Can I Convert 25FPS 720P To 23.976?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2011, 21:47 -
How To Join Flv Video Together Keeping Sync
By jamespoo in forum EditingReplies: 5Last Post: 15th Oct 2011, 07:28 -
Recorded TS file change to 25fps instead of keeping it to 50fps in mkv.
By Dazzler1985 in forum Video ConversionReplies: 1Last Post: 18th Apr 2011, 17:01 -
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 16:34 -
how to convert a subtitle from 25fps to 23.975fps?
By Ankin in forum SubtitleReplies: 2Last Post: 16th Jun 2008, 15:28
