Okay, here is my situation. I am wanting to watch movies at work on VCD's, and I have done it before several months ago. But the movies that I copied recently aren't working. I used EasyVCD to rip the movie. Then I used Sony CD Extreme burning program to make the VCD's. When at work I used a few programs to try and open the dat files with no success. I tried using Divx player, Windows Media Player 9, and Medfia Player Classic. Also, the movies worked at home on my dvd player.
Thanks in advance
Maybe your employer has figured out that you are wasting his time on the job and has installed a neat little monitoring tool to prevent you from watching your VCD's? Or something has changed on your home computer? Do the VCD's play okay on your Home Computer?
Try burning your Vcd's with VCDEasy (the last free version will do).
If you Vcd's were playing successfully at work before, what has changed in your creation process? Are you using different/worse cdrs?, burning at a higher speed?, using different authoring/burning tools? codecs removed from works computer? Any of these could be the cause. -
If you're going to open the .dat file, why go thru the hazzle of authoring as VCD at all? VCD are meant to be played "as a disc" - just like a video DVD, on a computer using the same software, like PowerDVD or WinDVD. If you just want computer playback, leave it as mpg (or even better, encode to DivX/XviD) and burn it as data.
/Mats -
Thanks for the help.
I'll try to encode it to DivX/XviD. Is there a program you would suggest? -
Negative to that.Maybe your employer has figured out that you are wasting his time on the job and has installed a neat little monitoring tool to prevent you from watching your VCD's?
I work security and we are allowed computer and internet access. We are not allowed portable dvd players though, because we might offend somebody with the movie we are watching. One of their main concerns is that we stay awake and alert and having something to help us is okay with them. -
What is your source? If DVD, there are plenty of guides to be found under Convert left.Originally Posted by hamiltonfighter
/Mats
problems watching some avi files
By tricks in forum Video ConversionReplies: 20Last Post: 4th Sep 2010, 21:02 -
By tricks in forum Video ConversionReplies: 1Last Post: 3rd Sep 2010, 00:55 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 06:57 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Problems copying a home-made DVD
By jj1807 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2007, 15:20
