I saw some conversion techniques to convert PAL to NTSC, but they use Windows applications that I cannot use. Are there any tools I can use to convert a VEIDEO_TS PAL movie to NTSC using a Mac OSX? Can ffmpegX do this? Can it check a VIDEO_TS and tell me info on it like if it's PAL or NTSC etc?
Yes ffmpegX can check the source format and tell you info like it's PAL or NTSC. You can try to convert the framerate (using DVD quick presets and "Decode with Quicktime") but sound sync problem may appear in some cases. Make sure that your player is not able to play PAL, as many players can do that and convert to NTSC on the fly. In such case you don't have to re-encode and lose quality in the process.
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19 -
MAC OSX - ffmpregX 0.0.9y VOR to DV conversion Help Required
By Raising The Roof in forum ffmpegX general discussionReplies: 2Last Post: 15th Nov 2008, 14:10 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
