I am trying to graduate from AC3 to 5.1 dolby digital. I have an xvid avi that I ran through gspot and gspot told me the audio is 5 ch. Anyone know how to make my dvd+r end up being 5 ch? I usually convert avi audio to Ac3 with ffmpeg or besweet, but I ffmpeg won't convert to 5.1 and besweet is not recognizing the avi. VDub won't do anything with the file either no will vdub mod... any have any ideas on how to utilize my 5.1 source xvid audio?
If you already have 5.1 AC3 and you want 5.1 AC3 then you really shouldn't be re-encoding.
ffmpeg as far as I know supports 5.1, just use -ac 6.
If it is an avi then VirtualDubMod should recognise it fine, even if you are missing the video codec. -
5.1 dolby digital is 6 channel AC3 - same thing. So there's no need to do anything to the audio bar extracting it from the AVI, which Virtualdubmod > streams > stream list > demux should be able to handle for you. Then convert video only, and let your authoring software mux your AC3 audio with your video. Job done.
If in doubt, Google it.
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 06:59 -
Right Channel Audio Only AVI!!!
By Sifu73 in forum AudioReplies: 6Last Post: 8th Jul 2010, 20:35 -
Divx\Xvid 2 DVDR
By eliqush in forum DVD RippingReplies: 9Last Post: 14th Jul 2009, 09:48 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35
