Is there any plugin to play Embedded MIDI files in Firefox other than Quicktime? QT quite frankly sounds like a big flabby ass expelling burrito farts when it comes to MIDI.
Results 1 to 9 of 9
for a codecs:
(quicktime) quicktime alternative
(real media) The Real Alternative
If what you want to do is control a media player in firefox, try FoxyTunes. (also available on the firefox extensions web site.)
MIDI is quite an old standard, and should be supported by windows and the sound card/chip drivers. I doubt you could expect much quality from any MIDI file (I may be wrong, but isn't MIDI mono only?).Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
No, it is stereo.
And it is the most space efficient way of creating polyphonic music.
The "quality" of the music from a midi file depends on how well the original person created it as well as your playback equipment.
Regards.Michael Tam
w: Morsels of Evidence -
Embedded MIDI is the fastest way to get me to close a page.
That aside I dont know one. Never had a problem with quicktimes playback either. -
I've just got one embedded midi on the main page of my site. Problem is it sounds fine through IE but sounds like crap in firefox. Firefox wouldn't play it at all until I set quicktime to handle the embedded midi for it. Its nothing too important and I'll probably change the whole site before long anyway. Been the same midi on there for years now.
//slightly off topicOriginally Posted by vitualis
I learned something new today.
I guess MIDI just reminded me of all my old DOS games.
midi can be 100's of channels and is a very much in use standard (go to the cubase or cakewalk web sites)Originally Posted by Skith"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
My cousin works with MIDI sometimes (does pro audio) he has some insanely expensive midi card that sounds freaking unbeliveable.
Fiddled with the settings in quicktime and found out you can change it to use the general midi control instead of quicktime's midi control. Sounds much better now.
Any MIDI gurus around here?
By sdsumike619 in forum ComputerReplies: 19Last Post: 26th May 2009, 01:49 -
MIDI Playback from Quicktime
By jonghyunchung in forum AudioReplies: 4Last Post: 28th Jan 2009, 20:52 -
mp3 to midi converter
By natty in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2009, 13:06 -
Any MIDI gurus here? re: SCD-10
By sdsumike619 in forum AudioReplies: 0Last Post: 22nd Oct 2008, 23:35 -
midi playback in vista 64
By johns0 in forum ComputerReplies: 1Last Post: 23rd Oct 2007, 04:44
