Hi im about to make start making my first movie as i just got a camera i was wondering what the best editing tool to use is?
Results 1 to 13 of 13
what ever you use to capture, DISABLE the preview. this will minimize if not eliminate the dropped frames. the program DVIO works well and uses minimal resources. When you capture to your HD it will be in DV avi format, you will need to edit and encode then author and burn. many people have many opinions on differnt programs, read the reviews and ratings. tmpeg is popular. Some like the do-it-all system hogs Ulead VS or Pinnalce studio. use the AC3 sound plugin to save a little space in the audio.
good luck
see mrbass.org for some good newbie hints and free programs. -
Try Ulead Video Studio to get your feet wet. There's afree 30 day trial so if you don't like it or want to try others you can.
Originally Posted by bhutchins -
Originally Posted by Shifty268
There's really only one other choice and that's mpeg audio which will not play in some NTSC players.
So you think it's good to demultiplex the DV then use seperate programs to do audio and video editing and encooding then multiplex them togeather and author; Or just one program and edit it as DV then encode and author?
one other thing whats the difference between Multiplexing and muxing
and demultiplexing and demuxing? -
What system are you working on: PC or MAC? (Hint: Update your computer details in your profile... While you're at it, do your location too.)
My crystal ball says... Top-end stuff: Final Cut Pro v4.0 for MAC, Adobe Premiere Pro 1.5 for PC.
Of course, if you'd have looked in the "Tools" section under the "Advanced Video Editors" category, you could've seen a whole load of tools and, invariably, feedback on them...
"mux" is short for "multiplex". Sticking "de-" in front of it is the reverse (i.e. "undo").There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Don't know - not used either so can't really comment. I'm currently happy with Premiere 6.0. I've heard Vegas 5 is really good too.
If only there was somewhere to read some feedback on each...
Carpe diem.
Simple wmv editing tool
By karebo in forum EditingReplies: 2Last Post: 5th Apr 2010, 04:40 -
A Tool for editing AC3 without recompress? (like mp3DirectCut)
By CactusMan in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 13:28 -
The Best and Simplest Video Editing tool.
By LarryLaser in forum DVD RippingReplies: 1Last Post: 26th Nov 2009, 23:57 -
What tool for video property editing?
By Nator in forum Newbie / General discussionsReplies: 3Last Post: 20th Sep 2007, 02:25 -
Tool for editing Divx
By ghassan99 in forum EditingReplies: 2Last Post: 18th Jun 2007, 18:02
